1 - 5 of 5 Posts
I'm looking to setup a quasi active front stage. I have midbass covered already and they will be playing up to about 300hz. I'm looking into the Dayton 2nd order Passives crossed at 4.5khz. The first mid that came to mind was the dayton rs100-8. Being fullrange it would have no issue playing that high. And then probably a LPG tweeter.
Here's where the issue comes in. the Dayton mid is only rated at around 84db sens iirc. Not to mention it will be off axis and I'm worried it may not keep up with the rest of my system volume-wise. I am coming out of a set of pioneer TS d1720c that just barely keep up as it is on some songs . I run 2 Dayton HO 10s on a kicker zx750. Does anyone know of a 8 ohm driver preferably 5.25 or 6.5 but can do 4 that plays down to 300hz, will work with the Dayton passive, and will maintain volume?
amp is Boston gt40
Mobile Audio SQ
You will have better luck posting in the correct area. Try the help me choose equipment area, that is after all what you are asking for.
yep, youre right. my bad
1 - 5 of 5 Posts
