1 - 15 of 15 Posts
Bass is not that great pretty boomy. AMT tweeter can sound harsh at times.
I have a few pieces that I would like to use for tweeter I have ScanSpeak Illuminator D3004/6040-00 Beryllium Dome Tweeter
Mids don’t have yet but was thinking ScanSpeak 11m
Lastly I have a pair of Illusion C8.
I would like to keep all stock locations my question is will my Burmester Amps under power these components.?
I’m not a aware of viable solution to keep my PCM 3.1. I also have a Helix DSP PRO. Want to keep simple as possible. I do plan on sound deadening with sound skins pro.
Sent from my iPad using Tapatalk
Discussion Starter #2
Also to add here are the specs of the Current Burmester
Thats my dream car congrats! If it were me I would see if I could tune it with the helix back into the factory amp if low level inputs re used in the Burm. Maybe add a sub if possible.
One I get situated today I'll look around
side note, what year is the car
2015
From what I understand the Burmester System uses a optic signal but it’s not one that an Helix DSP Pro can decode.
Anyone? I’m going to start dampening the doors this weekend and start fabricating the tweeter mounts. Can’t stand the Burmester amt. need to see how much space I a have under the mid in the door to see if a 12m or 11m will work. Not sure on enclosure volume on the door panel. It’s sealed I do know that question is it large enough to accommodate the 12m or 11m.
Update: I just ended up replacing the tweeters and the mids using the stock amplification. Used ScanSpeak tweeters and mids. Much better. I also sound deadened the doors bass was improved quite a bit.
After reaching for weeks there isn’t a whole lot of options that work with the Burmester system (MOST HUR 31).
It’s been a while since I have been on but the weather is getting cooler in Florida. So I’m digging into getting this going. Question is has anyone messed with the latest mobridge DA-G2.PRO? If please chime in. Where can I get one from? Emailed mobridge multiple times and got crickets. How much do they run?
I am using a mObridge DA.G2-PRO in my BMW X6-M.
Works perfectly (this is the 3rd mObridge unit I've had - in various vehicles).
I believe SkizeR is a mObridge dealer (in NY).
Discussion Starter #12
Ok thank you
here is what I did to my 2015 Porsche 911 turbo
Focal utopia M TW 3.5Md 8" doors
mosconi 4/10 and mosconi 5/30
DSP bit one hd
kenwood ddx9906xr
Discussion Starter #14
That is pretty sweet. I’m wishing I got a car without the Burmeister system. Haven’t been able to get a solid confirmation that Mobridge has a solution for it.
I shopped for a long time, looking for a car without Bose or Burmester. It's hard to find one, especially in the higher trim models.
I have a 2015 C2, thankfully with the SPP system. No MOST to deal with. Here's how it turned out:
https://www.diymobileaudio.com/threads/2015-porsche-911-carrera.415081/
Still love it! There are links in there for 3D printed speaker adapters for the tweeter using MD-102 tweets & 4" mids for Esotar 430's and DA RS100p's.
1 - 15 of 15 Posts
