1 - 1 of 1 Posts
· Registered
Not sure how to use the box design programs and can not find one that works on Mac anyway. I need a box for an Expedition. It will be one box but two chambers. The first will house a 15" MoFo and the second will house (2) Sundown Audio 12's.
Mofo-
MOFO-152X
Fs 24.07
Qms 6.103
Vas 3.761
Xmax mm 15
Xmech mm 22.5
Qes 0.48
Re 3.95
Znom 4
BL 21.00
Power (Watts) 1700
Qts 0.445
SPL 86.9
V.C. Size (in.) 2.5
V.C. Imp DVC 2
Cut-out 14.125
Depth 8.125
Recommended Enclosures
Ported 4.00
Port (2) 4x11.75
Tune Freq. (Hz) 29.7
F3 Hz 28.09
Sundown Audio 12's
RE: 3.8ohm
Fs: 35.8 hz
Qes: 0.56
Qms: 6.79
Qts: 0.52
Le: 1.85mH
Vas: 47.6L
BL: 15.4NA
Cms: 0.13MM/N
Mms: 156.6grams
Sens: n/a 1w/1m
Xmax: 12mm one-way linear
RMS: 400 watts
Enclosure Suggestions:
Ported: 1.5-2.0 ft^3 @ 35hz
Displacement: 0.12 ft^3
Outside Diameter: 12 1/4"
Depth: 6 1/2"
Cut-Out: 11 1/8"
Will someone please help me with a design and cut sheet???
1 - 1 of 1 Posts
