Hello!
This year I decided to try my first custom audio solution in a VW Touareg (2009) and I am having trouble with it. I had the hardware install done by a shop (everything works perfectly, also great looking) but it is me who has to do the software tuning.
The DSP is Mosconi/Gladen 6to8 Aerospace and the speakers are Gladen, subwoofer also Gladen with custom built enclosure.
The tweeters and midranges are installed in the A pillars (almost with no angle - facing each other) at ear level and the midwoofers low in the doors in their stock location. The subwoofer is in the trunk, simple box centered on the backseats' back.
All amplifiers were (physically) set to a maximum safe gain level (measured by the shop guy with oscilloscope for clipping and turned down to a safe place).
Things I have done so far:
- midbass (6") HP 80Hz, LP 350Hz;
- midrange (3") HP 350Hz, LP 2500Hz;
- tweeter (1.5") HP 2500Hz;
- set the delays - measured with tape from the tip of the microphone to each speaker grille's center, entered the distances in the calculator AudioFrog provides and then the milliseconds in the DSP;
After these the image is focused in the center, everything sounds natural but the frequency response is crap, voices move around, some parts are harsh and others you can't hear etc., but the sound is somewhat listenable to. It sounds as if there's amazing quality, but **** tuning.
What I did next was try to flatten the curve towards AudioFrog curve which I managed to match within 1dB (except for big dips) by only cutting frequencies , but it sounded horrible. I calculated each Q factor with the recommended formula and tried to not do any surgical Qs (like 10) as much as I could.
The tweeters sounded as if they struggled to produce music and the midrange was shouty and harsh and felt like everything was screaming at me for dear life. The midwoofers and subwoofer blended in nicely, tight bass coming from the front of the car.
Now I have no idea what to do to make it sound better and I am asking for your input. I have measured the system with no EQ or digital Gain modifications so you can get a better view.
Left Channel:
Right channel:
Center (both channels playing):
Delays:
- checked the polarity of the speakers with the guy that worked on my car -> all are correct;
- set the crossovers according to AudioFrog guide with LR24 filters (two BW12 for each LP/HP):
Left Channel:
Right channel:
Delays:
