1 - 5 of 5 Posts
Hey guys - I'm trying to hook up my 300.4 and 500.1 JL amps in my 2010 Camaro - it currently has the Boston "Premium" system and I would like to replace the interior speakers and add a couple amps...
I have a AC LC6i, I have some Audio knowledge but due to the factory "system" I have no idea on how to hook this thing up - my rear speakers (6x9s) are "bi-amped" from the factory and the fronts have midbass in the doors and tweeters up top so I'm not sure about how the factory speaker wires should go into the LC6i
I guess my questions are:
Do I use the pre-amp signal or do I tap into the wiring after the amp?
Since the rear speakers have 2 sets of wires running to each speaker can I just tie the two +'s together and the two -'s together creating a Left and Right Rear signal instead of a Left Low/Left High and Right Low/Right High?
Does anyone know how the signal is split to the front tweeters? are they on the same signal as the midbass?
Here's what I could find as far as a wiring diagram:
Any help would really be appreciated
So does this mean the factory amp has to stay installed? I was hoping to eliminate the facory amp all together...
1 - 5 of 5 Posts
