1 - 5 of 5 Posts
I'm looking for a sub to replace my current idq10v1. I really like the sound of it just looking for a little more output. I have no restriction on box size but will be using a boston gt-22 to power it. Specs read 270x1 @ 4ohm and 400x1 @2 ohm all at 12.6v. other restriction is budget. I'm looking to stay below about $150, not afraid of used equipment though. What would you do?
Are you looking for 10 or 12 inch subwoofer? Ported or sealed box? If you like the current sound, perhaps you could trade your sub for a 12 inch IDQ v3 or add a second 10" IDQ?
10, 12, 15 doesnt matter to me. Also the box will be built after the sub is selected so ported or sealed doesn't matter either. I have tons of room, its going in a jeep cherokee. Obviously I've thought about an idqv3 but it doesn't quite fit my power restraint or budget being about 750 rms and going for about $200 used. I've also looked into getting another idq10v1 but they are damn hard to find. alas i feel as I will have to move away from the idq subs and on to something different. the ID12 is something that I've looked at a little bit but not sure how much of a difference in sound quality im looking at between the newer id and older idq.
The fact that IDQ's RMS rating is 700watts does not mean that it will not work well with a lesser amplifier. According to WinISD, IDQ12v3 has a tiny bit higher sensitivity than such subwoofers as RE Audio SEX/12, Infinity Kappa 120.9w or Alpine Type R. I have a Kappa 120.9w running in my Taurus on just 250watts, and I find its output satisfactory enough. (However, I want to upgrade my amplifier to provide 400-450watts RMS eventually as I move to class D tech) Perhaps the issue is with the cabin gain inside of an SUV being less than inside of a sedan? I can see why you may not be satisfied with the current setup.. a 10inch sealed box sub will not sound very loud unless it's a high output subwoofer like IDMAX or JL w7.
Given your budget, an IDQv3 would probably be out of reach, but 12 inch subwoofers like Alpine Type R or RE Audio SEX/12 are within your reach. Both are proven performers in either type of box. As the way of least resistance, I would try them first in a sealed box for best SQ. If that didn't work, perhaps move to a ported box.
1 - 5 of 5 Posts
