Umm, I don't think there is any reason to add mass to A pillars, but perhaps wrapping some foam could bring the noise level down (if there is any here).
So we talking about something like a Second Skin Overkill / Overkill pro or even maybe Luxury liner pro? I know I have seen some ppl put stuff on there like adhesive mat (ex. Damplifer Pro) but am not sure why and/or if anything else is being used.Umm, I don't think there is any reason to add mass to A pillars, but perhaps wrapping some foam could bring the noise level down (if there is any here).
Yea See I wasn't so sure since I am going to have the dynaudio esotar2 110 tweeters in there and since there so big I didn't know if they might be some crazy resonance problem. Any type of foam I should be looking into? Maybe the overkill/overkill pro or luxury liner pro? I am not sure what foam you guys are talking about here? Also since this tweeter is so big do you think I am going to have any other problems I should look into to working on?A little bit of vibration damper might help if you're getting any resonance and lining the backs with foam will help eliminate any rattles. Tweeters don't transfer enough energy to the mounting surface to be a huge, fill them with concrete, sort of problem.
Luxury Liner is for blocking sound. One of the Over Kills should be fine. Is the tweeter so big that you are going to have to build a pod or make other drastic mods to the a-pillar trim? If so, all bets are offYea See I wasn't so sure since I am going to have the dynaudio esotar2 110 tweeters in there and since there so big I didn't know if they might be some crazy resonance problem. Any type of foam I should be looking into? Maybe the overkill/overkill pro or luxury liner pro? I am not sure what foam you guys are talking about here? Also since this tweeter is so big do you think I am going to have any other problems I should look into to working on?
Yea the tweeter is 3 inches Overall dimension ø 111 x 41 mmLuxury Liner is for blocking sound. One of the Over Kills should be fine. Is the tweeter so big that you are going to have to build a pod or make other drastic mods to the a-pillar trim? If so, all bets are off![]()
So you wanting me to put polyfill behind the whole A-pillar cover? So basically your saying put polyfill all beind the hole A-pillarAll id say , if you are worried about it i would stick a sound dedner of your choice to the a piller and stick some wading" like bass box filling" on the a piller coverfor a tight fit.
Hope this helps.
ATB
Yes mate you go it, all the way down of the a pillar cover, will take out all rattlesSo you wanting me to put polyfill behind the whole A-pillar cover? So basically your saying put polyfill all beind the hole A-pillar
personally I think you might have your priorities wrong.My dealer is making the tweets fit in to the A-pillars I am not sure how he is doing it.
I see what you are saying I have alrdy talked with my dealer and me and him talked about where to aim them at and we looked over the vehicle and figured things out to be. Anyways He also competes in some shows not sure which ones but he has trophies for mean streets and some other shows. He knows what I am going for so we are making this to be what hopefully is really good. I would be doing this work myself except I dont know how to mold/fiberglass and since I am not skillful in that area I am paying someone to do it right. If I feel it is not right I will get it fixed. How ever I am doing the door stuff myself. I just dont have the tools or a truck to do the work myself or I would. I wish I HAD A TRUCK!hmm.... I have a question.
You are building this vehicle for competition right?
You have done an incredible amount of prep work, deadened everything all the way to your headlights, had your car completely apart, spent thousands and thousands of dollars on equipment...right?
and now.......
This is probably where you should be taking a more active part. Not that you have to build them, but at least determine where they will go and how they are aimed...etc.
you will probably be able to process out any issues, but at the level you are trying to accomplish not knowing where they are going just doesn't seem right....... and even with processing you should be trying to do as little of it as possible.
anyway, can't wait to see how it comes out.
