1 - 6 of 6 Posts
Im going to cross my tweeters at 2.5k what capacitor or bass blocker do i need to protect the tweeters. They will be powered by 35w each .
the speakers are infinity reference 6.5 components that i will run in network mode off a pioneer nex and other amps .
thank you.
Good place to start, here. You won’t find much response on this forum for this question because people ask it all the time.
2019 Subaru WRX Base 6-speed
Ready made
2010 Jeep JK / 2005 Volvo S60R / 1991 Volvo 744TI SE
To be the most accurate, you'd need to know the actual DC Resistance (Re) values of the tweeter. Sometimes the MFG will provide this in the TS parameters, or you can measure the Re with a DMM. Unfortunately Infinity (Harman) isn't known for providing that data freely, so best we can do is guess. Honestly it should more than do for your purpose, since you're just using it as a bass blocker and not an actual crossover. Its basically just half of a 1st order crossover.
Assuming you've got the Infinity REFERENCE 375TX tweeter from the REFERENCE 6530CX set, they list* the 'nominal' resistance of the tweeter at 3ohm. You wanted a XO point of 2500Hz, so we'll use roughly 1/2 that for the blocker. You'll need a ~44uF non-polar capacitor for each tweeter.
Parts Express has 47uF 100V Electrolytic Non-Polarized caps for $1.76/ea which will work fine for your application, but unless you order other things to get the free shipping option buying the 10pk from Amazon is slightly cheaper (and...you'll have spares).
6db filter:
Code:
------------------- * 1,000,000
[(2∏) * Re * Hz]
6.28318 * 3 * 1200
22619.448
0.00004421 * 1,000,000 = 44.20974
* https://www.infinityspeakers.com/on/demandware.static/-/Sites-masterCatalog_Harman/default/dw9e84a64e/pdfs/Infinity_Reference_Speakers_Spec_Sheet_English.pdf
1 - 6 of 6 Posts
