1 - 2 of 2 Posts
Product Brand & Model:pRS-D2200T
Condition of all items: New in Box
Premier PRS Series 2-Channel Full-Range Class D Car Amplifier
RMS Power Rating:
4 ohms: 150 watts x 2 chan.
2 ohms: 300 watts x 2 chan.
Bridged, 4 ohms: 600 watts x 1 chan.
Max power output: 600 watts x 2 chan.
PWM (Pulse Width Modulated) MOSFET power supply
Wired remote bass level control included
LED power indicator
Selectable Bass EQ (0,6,9,12 dB bass boost at 50 Hz)
Full-range Class-D ICEpower gives the amplifier incredible efficiency that enables it to put out tight bass with minimal lag effect as well as crystal clear mids and highs
Independent left and right channel circuitry gives this PRS amplifier a cleaner signal output as it maintains channel separation while eliminating signal interference
LT OP AMP (Linear Technology Operational Amplifier) prevents any sound quality deterioration
Energy saving design allows this PRS amplifier to draw less draw from your vehicle's alternator, giving you improved gas mileage
Full custom-made power supply capacitor bank
Compact design
Speaker-level inputs with included high-level to RCA adapter
Preamp RCA outputs
Compression-type speaker terminals
Balanced isolator input circuit
Gold-plated RCA level inputs
Gold-plated screw terminals
Variable high-pass filter (40-500 Hz, 12 dB/octave)
Variable low-pass filter (40-500 Hz, 12 dB/octave)
CEA-2006 compliant amplifier
Frequency response: 10-50000 Hz
Dimensions: 12"L x 8-3/8"W x 2-1/4"H
4-gauge power and ground wiring is required for installation. Contact us for information regarding a discount on select amplifier kits when purchased together with this amplifier.
Total Price: $200:
Additional info:I sold this and it was shipped. Buy had put some stupid stuff in the name section of his paypal account and UPS couldnt make out the name so they held it for a week and tried to contact the guy. he never replied so they sent it back to me. Now I am just seeing if anyone else wants it cause the guy is a real chump. wants to stick me with the shipping.
Discussion Starter · #2 ·
last chance otherwise I send it back out to the ******* and hope that its done . I almost dont want to but I dont need to sit on it either.
so if anyone wants to buy it the is last chance.
1 - 2 of 2 Posts
