I have about two and a half speakers working in this car, order these Kickers dsc650 off of amazon. Much louder than the almost completely blown front speaker. I quickly realized that that metal stamped steel bracket is not going to be very good for any sort of speaker, so I read through this forum on fixes but didn't quite find what I was looking for. For the rear I came up with this idea to use black expanding foam to seal up all sides of the steel and two reinforce it, I saw expanding foam used for two subwoofers to seal up tight spots against a vehicle before when the entire trunk was used as a box so I said what the hell, let's do it.
I wish I would have had more time to think this over, I don't mind this styrofoam sealing up the forward part bottom and back part, but the top part I wish I would have sealed up those holes at the top to give the speaker a little more air volume. I an feel the steel vibrate, should have just cut some mdf to size and fitted it over the panel.
I don't think this speaker has enough Air volume but it does sound very good, what do you guys think?
The front is getting the Tupperware mod
