1 - 18 of 18 Posts
Photos are done, specs and enclosure info will be up soon. Below are shots of the new Dcon 10, it is a shallow mount. It is still a great SQ option that blends really well, and can have authoritative output on modest power. The newer design has greater cooling and more motor force along with a little more power handling and enclosure flexibility than the original Dcon.
Sub Woofers - SoundSolutionsAudio - DCON - SSA STORE
Very nice sir! Some awesome upgrades made to the new line for sure.
So when is specs and info coming ?mounting depth at least?recommended box etc.If there ready to ship shouldnt this already be known.
Specs and info will be up soon. They are known, but we will post them up the moment the drivers are ready.
Its two days till shipping , any word on specs or testing?
There is a small batch of Dcon's in the process right now, the rest are waiting on magnets to arrive.
These are PRE-PRODUCTION SPECS!!!
DCON10
DCR 7.8 Ohms (D4 wired in series) 3.4 (S4 coil)
FS 29.6 Hz
QMS 4.51
Qes .31
Qts .29
Mms 111g
Vas 35.0 l
SD 310 cm^2
BL 22.8 15.05 (S4 coil)
SPL 86.5 1W/1m
DCON12
FS 28.1 Hz
QMS 4.98
Qes .34
Qts .32
Mms 136g
Vas 78.1 l
SD 480 cm^2
SPL 89.2 1W/1m
DCON15
FS 32.5 Hz
QMS 5.66
Qes .45
Qts .42
Mms 148g
Vas 149.2 l
SD 810 cm^2
SPL 92.4 1W/1m
Bump for woofer mounting depth information. Thank you.
DCON10
FS 29.6 Hz
Re 7.8
QMS 4.51
Qes .31
Qts .29
Mms 111g
Xmax 17mm
Vas 35.0 l
SD 310 cm^2
BL 23.1 15.05 (S4 coil)
SPL 86.5 1W/1m
400wRMS
Displacement 0.09ft^3
sealed .75
ported 1.0 @ 31hz
mounting depth 5.375"
DCON12
FS 28.1 Hz
Re 7.8
QMS 4.98
Qes .34
Qts .32
Mms 136g
Xmax 17mm
Vas 78.1 l
SD 480 cm^2
SPL 89.2 1W/1m
400wRMS
Displacement 0.13ft^3
sealed 1.0
ported 1.75 @ 31hz
mounting depth 6"
DCON15
FS 32.5 Hz
Re 7.8
QMS 5.66
Qes .45
Qts .42
Mms 148g
Xmax 17mm
Vas 149.2 l
SD 810 cm^2
SPL 92.4 1W/1m
400wRMS
Displacement 0.16ft^3
Sealed 2.5
ported 3.5 @ 31hz
mounting depth 7.25"
Discussion Starter #13
They are the most shallow sub line we have. To go under 6" for a 15" sub, it would mean a very different design in terms of basket/motor arrangement.
Any way to get one of these (dcon12) faster than the 3 week build time listed on your web site?
1 - 18 of 18 Posts
