1 - 1 of 1 Posts
Hi
I hope somebody here can give me a bit of insight on how I should be connection my steering wheel control unit on a 2011 honda cr-z.I have a spiral audio ix-ho002 swc interface.In the instructions don't have my head unit listed which is the first problem.It just says if you have a self learning head unit which mine is that I should not cut any loops and to use key 1 key 2 and ground wires.and to to refer to the radio manual for configuration of swc.I figure okay no problem then look in the radio manual which says if you are using a external swc module connect only swc-ir wire to the output of the module.I am confused as to which wire they want me to connect it to key 1 or key 2 also it says power supply 5v uses swc when first activated.so what ecatly am a supposed to connect the 5v wire too?
1 - 1 of 1 Posts
