1 - 3 of 3 Posts
How do I check why I'm not getting power to the 1 amp? From what I can tell, there is a fusible link from the battery to a distribution block which then transfers power to 2 amps. 1 amp works, the other does not. Both amps work fine as I moved one amp from one to the other power source and it's apparent that it is not receiving power from the one source. What should I check next?
Make sure that power wire is screwed down tightly at the distribution block or switch the 2 wires from the distribution block to see if that side of the dist. block is good or not.
1 - 3 of 3 Posts
