G
Guest
·Let me start off by saying that I'm an "old schooler" through and through. Started in car audio back in the late 80's/early 90's. It's always been a hobby. I spent many years out of the hobby and in the last few years, I have gradually gotten back into it. I've read tons of forum posts, articles, etc... lately on tuning. I am in the process of upgrading/building a full active set up. I am wanting to play with the tuning extensively, using a lot of the latest technology. I want to make sure my drivers are all in phase, determine the ideal crossover points, set amp gains properly with no clipping, etc. From what I've read and watched on youtube, it appears I will need the following to accomplish my goal:
1. A good digital multimeter/clamp meter
2. An oscilloscope
3. Various test tones
4. Lots of time
5. A dummy test load for my amp testing/settings
6. An RTA
I have a cheap DMM, but would like to get something a little better quality.
I do not have an oscilloscope. I have a **** ton of test tones (AS2K disc set and a Focal JMLab disc set). I have the time. I do not have dummy loads (or the knowledge to build them) and I do not have an RTA.
I am not a professional installer and never will be. All equipment will be used primarily for tuning my own stuff, and potentially to help some friends with theirs at the most. For that reason, I'm looking for the best bang for the buck. I don't want cheap junk that will not give accurate readings. But, I don't want to spend $500 on something that I could buy for $100 and get the same results.
For the oscilloscope, DMM and RTA; what would you recommend or what is everyone using? I have a windows PC and an Ipad, so anything PC or mobile based is fine as long as it is accurate.
For the dummy loads, I found these which will handle my 4 channel amps just fine. My sub amp will be running 1500 watts max @ 1 ohm. It's a Sundown SAE1000d, and the highest clamp tests I have seen for it is in the neighborhood of 1200 watts. Does anyone have any recommendations on where to get a dummy load for the sub amp? If someone could tell me how to build one, I would be willing to give it a try, but I am very, very ignorant when it comes to resistors, etc. My ultimate goal is to initially set the limits of all my gear and then fine tune for my own preference and sound quality. In the end, I'll have about $3500 invested in audio gear. That may not seem like a lot to many, but it is to me. Spending a little more time and money to prevent damage, clipping, blowing equipment is worth it to me. I would love to get some input on this stuff, including links of where to buy what. You can PM me as well. Thanks in advance.
2. An oscilloscope
4. Lots of time
6. An RTA
