1 - 20 of 21 Posts
what about a comp set?
perhaps seperate crossovers, with adjustable features. or a crossover plan like zaphaudio.com has for the MT sets. that way you can skip making them, but still make plans available.
Hmm if they sound anything like my 26's there gonna be awesome, but better low end extension is always good. I can't really use the LPG's lower than 3k or around there.
DIYMA Founder
I'm still debating between a pre-made passive, and just publishing a free design for the passive in case anyone wanted it.
Regardless, you're still going to need to eq as with any other set :)
how big of a flange :)
DIYMA Founder
Well... I'm trying to get it in the same exact dimensions as the d2904/6000-1 scan-speak. But I'd like a bit more excursion, and a flatter dome profile. 1khz is really pushing it, but I think ~1.5khz is doable as a lower end cutoff.
The Zapco Reference Tweeters run down to about 1K as well. As far as the crossover, I would have to agree that give them the information but don't waste the money on building them. Every car is different and should really use a crossover network built for the responses in that car. Good luck.
Ya, Zapco's new tweeters are amazing. I'm looks for an inexpensive mid to pair up with my XXX mids (already installed). I have some LPG26na's, but I'm interested in getting a pair that will play lower.
What's up with the tweeters npdang?
Yea Dang any updates....On midrange, midbass or tweet for that matter, and Didn't you mention a sub too? Sounds like you've been buisy...hows things going with them?
1 - 20 of 21 Posts
