181 - 187 of 187 Posts
1999 Jeep Wrangler TJ
Discussion Starter · #181 ·
I retract my earlier statement. There are some songs where it's definitely muddier. I have a feeling I'm going to be spending some time tuning this weekend 😆
Discussion Starter · #182 ·
This sounds so much better. I didn't know what I was missing when it came to midbass.
Light Font Screenshot Software Technology
These are my current settings, set by ear. I'm taking a break from my drive and tinkering. I'll run REW tomorrow to get some actual data, but so far, wow.
I changed the BW to L-R slopes. I was using BW as they were really helping with the null, but changed these since it's universally recommended to start with L-R and I figured it was worth a shot. Seems to have taken some of the muddiness out of the bass.
Discussion Starter · #183 ·
Rectangle Slope Font Line Screenshot
Amazon misdelivered my hammer crimper, so instead of playing with wiring as I intended I decided to deaden the speaker bar and polyfill a bit. Afterwards I did some quick tuning.
So far I haven't followed any official guides for tuning an active 3-way. I'm just doing what I did when I was intro-tuning a 2-way: tuning left, tuning right, then together.
After playing with crossovers, slopes, phase, and a little EQ, I've managed to get it here. The bass is overall much better, tighter instead of boomy. I find that I'm turning up the sub a lot less now, I think I was compensating for the lack of midbass by cranking that bass knob. I still have a bit of a dip at 180 - 190 , and now this dip at 90. I'm not sure if I should try to find a way to fix those dips or just EQ down at 130 and 270 to flatten that area.
Discussion Starter · #184 ·
With smoothing at 1/6:
Rectangle Azure Slope Font Screenshot
Is there a pattern to these dips that indicate a single issue, or is this just what you would normally expect from the crazy acoustics of a vehicle?
Those are probably normal. I have a nasty dip around 90 hz too, even with just subs playing.
Easy why to tell is to take near field measurements of individual drivers.
I'd guess <1000Hz or so would be cabin modes and >1000Hz is stuff like comb filtering from reflections. I'm just guessing at 1000Hz, not sure what the cutoff is actually.
Discussion Starter · #187 ·
Ahhhh, makes sense.
I'll try EQ'ing down to smooth those peaks a bit. That dip at 550 is a little disconcerting as well. Though in my vehicle I guess a dozen cabin mode issues are to be expected.
