If you’re making the point that you can eq everything else down around the null then that’s all good… but… you can’t cure the null and if you drop the rest to match your null will still be there and have two lots of phase at your ears both at a higher level and you will get worse results in some cars than just leaving a deep narrow null as it is and levelling the rest to suit at the higher level than the nullAlso, I don’t know if anyone else has mentioned it but ~7db nulls are childs play with eq. Did you say that making high q cuts around that null makes the null deeper with careful enough q usage that it’s definitely not acting on the null?
the other solution is relocate midbass to somewhere without a null where we need to use the driver, and see what happens after than 👍🏼
