1 - 7 of 7 Posts
· Registered
Technically 6 ohms. But only for the frequencies where the 2 speakers intersect. In other words if your 6.5" is playing the frequencies 80-2000 hz and your 4" is playing 150-4000 hz, the amplifier will see an 8 ohm load for frequencies 80-150 hz, a 6 ohm load for frequencies 150-2000 hz and a 4 ohm load for 2000-4000 hz.
Clear as mud??? Good.
· Registered
In theory it would be 6 ohms, but I dont think that is possible. But I am probably wrong on both questions...
· Registered
2.66666666 ohms
Final impedance= (R1XR2)/(R1+R2)
Down and dirty for calculating 2 impedances
Many drivers=(1/R1)+(1/R2)+(1/R3)+........
Final impedance= 1/above answer
So for example if you have 2X4 ohm drivers and 1X8 ohm
You could do the first calculation twice;
(4X4)/(4+4)=2 ohms
Then
(2X8)/(2+8)=1.6 ohm final
lotta math
2nd method
(1/4)+(1/4)+(1/8)+=0.625
1/.0625= 1.6
the 2nd method is easier with a normal calculator using the memory function
Keystrokes are as follows
1 / 4 = M+ M+ (there's 2 4 ohm in the calc no sense in doing it twice)
1 / 8 = M+
1 / Mr
Bingo!
Hope this helps!
Chad
· Registered
The final impedance of a speaker load will ALWAYS be less athan the lowest impedance in the formula.
It's a load if you take a load and put a lighter load on top of it then it does not get lighter.
But, as already mentioned this is only true if the drivers are playing in the same passband, and remember it's impedance not resistance. These are nominal numbers and impedance curves can widely vary from driver to driver.
Chad
1 - 7 of 7 Posts
