This is an area where I struggle a bit understanding what I am seeing. I took a bunch of REW measurements, so lets look through them together.
I've been listening to some of my playlist songs and it can be a bit harsh at high volume. Vocals sound pretty good, but there is some harshness that I want to get rid of.
The goal for the tune is to learn and get it sound more pleasent than it currently is, I'm not expecting a dialed in tune as changes are still happening with the build. So, these questions were asked to be added here.
Have you confirmed that the OEM head unit's output does not clip at its 28/30 volume setting with both a 1kHz and 40kHz Sine Wave?
Answer: It's digital from NAVTV Zen to the Helix DSP Pro Mk3, there isn't any way to check for clipping. When gains were set, 40Hz and 1KHz -0db tones were used with volume maxed at 30 without clipping using DD-1. See post 34 here on my gain and amp structure.
Helix DSP Pro MK3 Gain Setup and other issues
Are you using some type of OEM interface...PAC AmpPro4, NAVTV ZEN, iDataLink Maestro, etc?...i.e. is that signal Flat and Full-Range?
Answer: NAVTV-Zen A2B. it should be flat, I have balance/face set to default center position and High/Mid/Low set to 0
And how are you getting signal from the head unit to your DSP?
Answer: SPDIF Optical from NavTV.
Please list your front stage and subwoofer drivers and their locations?
Answer: This is a touch subject, but tweets and mid-range are in custom pillars, mid-bass in the doors, single IDMax 12 in the rear.
Morel Piccolo Pillar
Morel Elate Carbon MM3 Pillar
Morel Elate Carbon MW9 lower door
Image Dynamics IDMax 12D4v4 currently, will be replace by 2 Raven 12XL
Mosconi Pro 4|10 for tweeters and Mid-Range
Mosconi Pro 4|10 for Mid-Bass and rear doors (There are currently no rear speakers)
Mosconi Pro 1|10 for Sub.
See post 140 for more detailed info on pillars. Helix DSP Pro MK3 Gain Setup and other issues
What are all of your crossovers set at initially?
Answer: Initial X-Overs are set at the recommended points based on Morels documentation.
Tweeter > HP 3300Hz -24db LW
Mid-Range > LowPass 3300Hz - HighPass 450Hz -24db LW
Mid-Bass > LowPass 450Hz - HighPass 60Hz -24db LW
Subwoofer > LowPass 60Hz -24db LW
Have you set at least rough time alignment?
Answer: Yes, current stage presents slightly below center of windshield.
What microphone and calibration file are you using?
Answer: MiniDSP UMIK-1 with calibration file provided with the mic.
This is my RTA settings. It's been a minute since I last used REW. All measurements were taken at 28/30 volume. Pink noise from my DD-1 CD was used via USB connected to factory head unit.
First up is all measurements except where noted were taken with the vehicle running. Second observation is, this system doesn't have nearly the output as my previous system. That's a topic for another discussion though. Anyway, here we go.
Vehicle baseline, no audio.
Front Left Tweeter
Front Right Tweeter
Front Left Mid Range
Front Right Mid Range
Front Left Mid Bass
Front Right Mid Bass
Subwoofer
Front Left Tweeter
Front Right Tweeter
Front Left Mid Bass
Subwoofer
