1 - 14 of 14 Posts
Looking at a JBL w12gti but its a dual 6 sub. Will my old school 2300 be OK driving a 3 ohm load or will it go up in smoke?
should be fine.
You will have to have a resistance curve at given frequencies to determine if it will run it fine. Just because its nominal is 3 doesn't mean it won't/ can't go all the way down to 1 ohm at certain frequencies.
Or you can run it and make sure it doesn't get hot.
Years ago I ran 3 JLw6 off 3 2300's with no issues.
They were pretty stout amps that seemed to handle it pretty well back then, installed many of them. I would DEFINITELY consider a cooling fan and maybe raising it up a hair with spacers though, they did tend to run on the warm side, warm enough to make the stickers on the bottom of them to fall off from the glue releasing.
Hmmm. the amp has a built in fan. probably nowhere to put an extra fan in my install though
Built in fan wonder what that means! Fans are used to cool off something that is to hot to run in spec....
DON'T DO IT
The driver has an Re of 3.2ohm with coils in parallel according to the manual, which the impedance won't drop below. So as long as the amp is stable to 3ohm or lower, he'll be fine. If it's not, then it's a crap shoot.
Just realized he was talking about a 2-channel amp, so probably not stable below 4ohms bridged.
It will be fine. I know people that have run them at 2 ohms mono w/o a fan, but was out in the open. I have one of those amps ran at 2 ohms mono.
1 - 14 of 14 Posts
