I have an awesome old school powerhouse of an amp for sale. I received it with the protection light turning red on it BUT it puts out full power and sounds **** good doing it. I wasn't worried because I had an external xover on it. The xover knob spins all the way around, so it doesn't work (hence the red light) but there is a bypass button for the xover and you can run any xover point you'd like through an external xover or through your HU. All other features work on it. Ratings are at 12volts, Class A/B. It's an awesome amp and I haven't had any issues running it daily to a set of solo-baric 15's for about 2 months. I'll guarentee against DOA. Looking for $325 shipped. Precision Power PC21400.2
2 x 350W @ 4 ohms
2 x 700W @ 2 ohms
1 x 1400W @ 4 ohms bridged
THD: 0.02% (4 ohms)
Freq. Response: 4.5Hz ∼ 100kHz (±0.5dB)
S/N Ratio: 115dB
Damping Factor: >500
Max. Current Draw: 230A
Fuse: External 160A
Dimensions: 25.75" x 8.9" x 2.24" (65.4cm × 22.6cm × 5.7cm)
2 x 350W @ 4 ohms
2 x 700W @ 2 ohms
THD: 0.02% (4 ohms)
S/N Ratio: 115dB
Fuse: External 160A
