1 - 18 of 18 Posts
I have a 93 acura legend coupe.I want to replace the bose system and still want the same sound quality but with a bit more kick(louder bass and voices).I have chosen a kenwood headunit,pair of 6x9 eclipse speakers they are big speaker with built in crossovers.Pair of 6.5 eclipse speakers same model as the back they are just the 6.5 model they are older speakers with built in crossovers also, they are new i had them for a while.What u guys think of this setup.They ran me bout 4 hundred for the 6x9 and the 6.5 ran me bout 3 hundred they arent cheap speakers i just know aftermarket usually dont sound as good as oem bose systems.What u guys think,what advice u got for me i want a elegant system.
I would most definitely disagree that aftermarket doesnt sound better than factory bose. The first thing i would tell you to do is think about deadening your door. It is shocking how much of a difference sealing and deadening your doors has on midrange clarity, midbass impact and overall loudness.
Also a key to a good frontstage is an outboard amp. HU amps just dont have the power to get the full potential out of a nice set of speakers.
Give us a budget to start with and we can go from there
Are you just wanting to replace your speakers and get an amp or were you wanting to add a sub?
If you are really stuck on those two choices i would have to pick the eclipse. but i think you could do much better for the money.
Regardless of which amp you choose i think for what you are wanting you should consider an active setup. That really opens up the possibilities as far as choices in speakers and tuning ability.
Discussion Starter · #9 ·
*Double post*
I already have the hu and the speakers so in stuck on that.As far as the amps i dont have one yet,i say eclipse and kenwood cuz i would like the system to concist of those 2 brand cuz i heard that a system comes out better if u dont mix so many brand.What amp would be better for the cash,Beside the kenwood excelon or eclipse?
I would not get stuck on the "everything should be one brand" idea. The only reason this is an issue is if you want things to match. Retailers try to convince you that your system will sound better when everything is the same brand because they don't want you to leave the store and buy a different brand that they don't carry.
Scrap that idea and you should be able to find a lot of good choices out there within your budget.
Discussion Starter · #17 ·
Ok thanks alot i always heard that to get a great system u have to use all one brand stuff, but know ima open my option alil more.I like eclipse sound quality its nice though.
1 - 18 of 18 Posts
