1 - 5 of 5 Posts
1995 Tahoe, Sony MEX-XB120BT, Infinity Reference 5032CFX 5-1/4" front, Kicker KSC41004 KSC4100 4x10 rear. Intermittent 'Output error' (may be with volume above 40). Sony says wiring or faulty unit. Done so far- direct 10 gauge to battery with fuse within 18" for power, 10 gauge ground to known good frame ground. All wiring direct to radio harness, all other wiring ohms out ok. Sounds great other than intermittent output error.
Any help is greatly appreciated, thanks in advance!
ps- if they want 10 gauge wire run for power and ground why do they only use thin gauge to connect it to the radio?
pps- assuming this actually is an 'output' error I'm going to run 16 gauge wire to each speaker rather than use the thinner factory wire.
Discussion Starter #2
update- error just went away.
Hello. I just bought one of these and also have a 95 tahoe. Did you end up changing the speaker wires? Have you had any problems since? I read that it will do this with the extra bass on. Wasn't planning on changing speaker wires but I don't want any problems. I went with new cerwin vega's ( 90-91db) so maybe I won't need to go louder than 45!!! Any input on this deck wouuld be appreciated. Thx.
I installed it for a friend. we did everything! it pretty much does it when it wants to, no rhym or reason. last step was to return it but since I haven't heard about it I guess he's tolerating it.
1 - 5 of 5 Posts
