Howdy
As I've mentioned before, I have a Scion xB. I finally got a Clarion DXZ785USB and the PAC SWI-JACK to hook it to the OEM steering wheel controls. The instructions look a little bit unclear.
Just what am I supposed to do? Shove the included resistor into the factory harness molex connector, then solder a wire to the end that's sticking out? That doesn't seem very clean or safe. I suppose I could mount the resistor on a breadboard inside a tiny project box, but that will make the whole harness job even bulkier.
I'm supposed to split the white wire from the PAC unit, and run half of it to one pin in the Toyota harness, and run another lead to said resistor and to another pin? How am I supposed to make this look clean, neat, and safe? If you've done an installation of one of these before, how did you do it??
Thx
Thx
