Thank you for viewing my posting.
I have 3 amazing hi-end car amplifiers for sale.
2- Phass amps from Japan 1- Tube 4ch and 1- 2ch
1- BNIB Audison Monoblock amp
My asking prices are as follows:
1. Phass TP-4100 Tube 4ch Amp - asking $1825+ fees shipped
Specs:
Power output 14.4V/4ohm 100W x 4
1KHz at THD 14.4V/2 ohm 130W x 4
Frequency response: 2 - 80KHz
S/N ration: >90dB
Stereo separation: 75dB
Idle current: 2.0A
Remote voltage: 10 - 17V
Input impedance: 20Kohm
Input sensitivity: 0.2 - 4V
Crossover frequency (HP): 50 - 200Hz
Fuse type: 15A x 4
Dimension (WxHxL, mm): 452 x 200 x 59
Made in Japan
2. Phass AP-225i asking $225+fees shipped
Specs:
・ 4Ω (12.5V), rated output / maximum output 25W x 2 / W x 2
・ 2Ω (12.5V) Rated output / maximum output W x 2 / W x 2
・ 4Ω Bridge (13.8V), rated output / maximum Output W x 2 / W x 2
・ Frequency characteristics 10Hz-80KHz
・ Input sensitivity 0.2V ~ 4V
・ Crossover (Hi) Hz-Hz
・ Crossover (Lo) Hz-Hz
・ S / N ratio 100dB or more
・ Harmonic distortion Rate (THD) 0.05% or less
・ Size 135mm x 56mm x 225mm
3. Audison SR1D Monoblock - Asking $ 325+fees shipped. This is Brand NEW in the box.
  • Nominal power (RMS) @12 VDC; 1% THD :
  • 4 Ch @ 4 Ω 200 W x 1
  • Output power (RMS) @14.4 VDC; 1% THD:
  • 1 Ch @ 4 Ω 280 W x 1
  • 1 Ch @ 2 Ω 460 W x 1
  • 1 Ch @ 1 Ω 640 W x 1
  • Dimensions WxHxD (inches): 8”7/16 x 2”1/8 x 11”3/8
  • PRE-OUT pass-through from high level SPEAKERS-IN input
  • Removable panel to hide and protect controls
  • Monoblock aluminium heatsink construction
  • Fanless convection cooling system
  • Strip fuse located on the control panel for easy replacement
  • Connections: Power supply terminals accepts 7 mm diameter (4 AWG) cable, Speaker terminals accepts 4.5 mm diameter (8 AWG) cables, Hi Level speaker and remote turn-on terminals equipped with removable connectors with screw fastening
  • “D” class topology, delivering 280W at 4 ohms and 640W power at 1 ohm
  • Phase control switch
  • Selectable Subsonic Filter
  • Bass Boost Filter
  • Continuosly adjustable LO-pass 24dB
Power Supply:
  • Power supply voltage: 11÷15 VDC
  • Idling current: 1 A
  • Switched off: <0.01 mA
  • Remote IN voltage: 7÷15 VDC (1 mA)
  • Remote OUT voltage: 11÷15 VDC (15 mA)
  • Internal fuse (AFS): 40 A
  • Consumption @ 14.4 VDC, 1 Ω,
  • Max Musical Power: 33 A
Amplifier Stage:
  • Distortion - THD (100 Hz @ 4 Ω): 0.3 %
  • Bandwidth (-3 dB): 18 ÷ 500 Hz
  • S/N ratio (A weighted, 1 V): 90 dB
  • Damping factor (100 Hz @ 4 Ω): 150
  • Input sensitivity (PRE IN): 0.3 ÷ 5 VRMS
  • Input sensitivity (Speaker In): 1 ÷ 15 VRMS
  • Input impedance (PRE IN): 15 kΩ
  • Input impedance (Speaker In): 100 Ω
  • Load impedance (Min):
  • 1 Ch 1 Ω
Input/Filters:
  • Inputs Pre IN / Speaker IN
  • Output Pre
  • Filter LO-pass: 50 ÷ 500 Hz @ 24 dB/oct
  • Subsonic 25 Hz @ 24 dB/oct
  • Boost + 6 dB; + 3 dB; OFF / @ 45 Hz
  • Phase Control 0° - 180°
Netbook Handwriting Font Rectangle Gadget
Cloud Rectangle Purple Font Violet
Product Rectangle Font Material property Cutlery
Rectangle Font Gas Metal Brand
Font Publication Packaging and labeling Handwriting Paper
Brown Rectangle Wood Material property Silver
No Trades and Cash only. Shipping to USA only.
