1 - 2 of 2 Posts
Well, they don't have gold plated boards...But they are solid and overbuilt amps.
Xenon X200.4
# 200W x 4 (4-1 ohm stereo)
# 400W x 2 (8-2 ohm bridged)
# Xe.load™: optimized for any impedance load
# Xe.tune™: 24dB Linkwitz-Riley subsonic and low pass crossovers
# Xe.flow™: variable thermal feedback controlled fans
# Tried and true triple Darlington output stage
# Buffered RCA full range thru output
# Remote Monitoring Display (RMD) port
# Low Pass Level control ready (LPL-44)
# Built-in Crossovers
# Optional Remote Voltage Display
# Optional Remote Low-Pass Level Control
# Variable input sensitivty
# 0 - 18dB Bass Boost at 45Hz
# CEA-2006 Compliant
# Dimensions: 22" L x 10.6" W x 2.5" H
Phoenix Gold Products
MS1000 TA
Unregulated class A/B amplifier.
Output Power per Channel at 1% THD (all channels driven)
4 Stable to 4 ohms bridged OR 2 ohm stereo *due to excess heat*
4 x 250W RMS @ 4 ohms (12V)
4 x 340W RMS @ 4 ohms (14.4V)
4 x 520W RMS @ 2 ohms (14.4V)
2 x 1,060W RMS @ 4 ohms bridged (14.4V)
2 x 1,900 W RMS @ 2 ohms bridged (14.4V)*
2 x 3,300 W RMS @ 1 ohm bridged (15 V)*
Fuse: 2 x 60A AGU type (internal)
Size: 35.3" x 11.5" (89.5cm x 29cm)
Frequency Response +/-1dB from 20Hz to 20kHz
Signal to Noise Ratio greater than 100dB
Lowest THD 0.02%
Damping Factor 500 to 1
Input Sensitivity 200 millivolts to 2 volts
Input Impedance 30k ohms
Input Voltage Range 10.5 volts to 15.0 volts
Typical current draw at idle 2 amps for each half
Continuous current draw @ full power** 90 amps for each half
Peak current draw @ full power*** 130 amps for each half
Bass Boost +/-12 dB @ 45 Hz
Recommended Fuse Size 120 amps for each half
Dimensions 34.0"L x 11.4"W x 2.4"H
Huge difference in price between the amps.
1 - 2 of 2 Posts
