OP, what is your size limit (width and height)? Where is your planned location for tweeter (distance from planned midrange placement)? What is your budget for the whole shebang?
Another round of questions:
Why did you choose those mids?
Why do you want (4)?
I can think of a lot of options off the top that would probably do what you need and none involve the driver you are looking at. The FR is just not good. Too much work to mate a tweeter to it; and that bump above 2khz is going to cause you headaches, as I mentioned earlier.
As for your plans, let's just assume the driver # and selection was sufficient... as others have asked, the bandpass is key. Lobing starts as low as 1/4 wave, CTC (center to center) spacing between two drivers. So, if you wanted the (4) drivers to behave as one, let's say the distance between the top and bottom is a vertical 6" (I'm avoiding pythagorean theorum for the time being because 6" is enough to prove the point), lobing will cause you issues above 562 using 1/4 wave. Above 1100hz using 1/2 wave. So, as you can see, even in the
best case scenario, you have lobing issues at 1100hz with quad 2" drivers. This is well before most any tweeter will come in to play. So, beyond the concern of using DSP to line everything up in time and amplitude, the physical geometry doesn't really support using a vertically stacked array of (4) 2" drivers in an ideal case. Not unless you have a really, really good tweeter. It just seems like a bad idea to me, TBH. I think you're wasting your time and efforts going down this road when other, simpler options work better.
If you knock that down to a pair of 2" drivers and can get ctc down to 4" (not likely to happen given most driver flanges) you are good to about 3300hz [(13500in/s)/(2in)/2]. And that's again a best case. But, that's enough to bring in a good tweeter in terms of mechanical capability (not including the potential concern with the distance from the mids to the tweeter). There are some really nice 3" mid options with relatively high efficiency, such as the
Faital Pro 3fe22 8ohm that could be wired in parallel, giving you a total SPL of 97dB @ 1w/1m. With their reduced flange size you can get half-wave lobing down to 2.1khz, which is enough wiggle room to cross a touch higher with a good tweeter to cover 2.5khz-3khz and above (depending on the final acoustic crossover).
If you need a 2" driver, then something *like* this would probably do the job well:
Vifa TC6FC00-04 2" Full Range Paper Cone Woofer 4 Ohm
There are a lot of options in the 2-3" range, though, that will meet your needs of a simple, mid-to-high efficiency MIDRANGE. MIDRANGE is key; if you get caught up looking at fullrange drivers or the like you'll wind up trading excursion for sensitivity in most cases which is not what you need. I'd be targeting 500-3khz in the 2" variety because obviously excursion is going to be limited and lobing is going to mitigate any need to go above the ~ 3khz crossover region.
I don't know if you chose those Vifa's due to size limitations, 4-2" mids is at least 8" tall... so I'd assume width is the problem with anything wider? Still, I think if you looked around you'll find a single driver that provides the efficiency you need in the bandpass you need. While you may get a higher beaming point with a smaller driver, you have to worry about CTC spacing and by the time you account for that, you're often no better off than where you were with a good single driver.
