Hi all, long time since my last posts and 10 years since my last car audio build so need som advice regarding placement of two 6.5" subwoofers in a tiny sportscar. The car's a 2004 TVR T350C.
I have on order a pair of Match pp72w-d woofers. If they don't turn up soon I might replace them with a pair of Sundown Audio SA6.5s. Both woofers use tiny enclosures both ported and even more so sealed.
The headunit is a Pioneer AVH7200dab. I am also using an older Zapco DSP8 and some Zapco ST4D 4ch amps. One amp will be bridged both front and rear to run the subs while the other will run my Seas Lotus reference speakers active in the doors
The subs/woofers will go in the rear hatch area. The questions is where in the hatch area? My initial plan was to fit them on the rear wall facing forward angled at half the angle of the rear screen. Approx where the dsp is in the below picture. The crappy 4" coaxials will be binned.
However I also have a useless cargo area cover (more like a sloppy horisontal blind) that sits in a cover. So my second possible placement for the subs would be to replace the cargo cover and make an enclosure that sits direclty behind the seats. Subs could then be angled 45 degrees forward, up or 45 degrees back (not preferably backwards).
The difference in distance to my ears for these two positions is maybe 50cm.
I am only wanting a nice sounding system with a bit of kick to it for rock music. I might listen som rappers delight, but mainly rock.
What do you think would give the best output and or sound?
