I'll keep it short and sweet.
  • 1 iDMax
  • 1 Kicker ZX1000.1
  • Wired to - 2 ohm
  • Max Height - 13.5"
  • Max Width - 30.5"
  • Tuned to - 28hz or 30hz
  • Built With - 3/4" MDF and 4" Aeroports
  • Possible Box Sizes (net. volume) - 2.72 cu. ft. or 2.55 cu. ft.
Don't want port noise. How long are my ports and what is the depth of my box for I planning on using the width and height listed above. It's going in my LS.
Please
Thanks.
Is it any different because of the use of Aeroports?
Not really, except you can't consider the entire length of the aeroport (tube + flares) as being actual port length. Part of each flare doesn't count, but someone else will have to chime in with an actual formula. In the meantime, I would consider a 17 inch aeroport more like 14-15 inches round about.
