I can not get my 701 to work as a stand alone, or even power on with out a ai-net connection. As soon as i connect the ai-net it turns on and works mostly. Everything functions correctly except I do not have a input select option in the setup menu. The manual says it should be there but it is not. So no auxiliary. That is a real problem. It was my understanding I could use this unit as a stand alone. Lastly I have a controller for a pxa700. I was told it is supposed to work the same but the buttons would be green instead of blue. Maybe the controller is the problem? Any suggestions would be greatly appreciated.
