Hi! I have run into a noise issue with my new install & any help will be sincerely appreciated.
Car : 2017 Maruti Suzuki Alto 800 (a very small Indian hatchback)
HU : Alpine CDA 9887 (been using it for 14 years without any problems) connected to DSP with a pair of RCAs
DSP : Audison Bit One (using a DSP for the first time)
Amp : Audison AV 5.1k HD
Front : Hertz Mille Legend 2 way (passive, plan to go active after a few months)
Sub : Audison Voce AV 12 in sealed enclosure
DSP and Amp installed on wooden board fixed to back of rear seat
RCAs and power cables run on opposite sides of car
Problem
Clicking noise while playing a CD at very low volume
Alternator hum when stepping on gas
Noise gets obscured by the music at increased volumes but the music sounds terrible
Aux instead of Master
If I switch off the Alpine HU and attach iPad or iPhone to DSP via aux cable and switch DRC from Master to Aux 1 there is no noise whatsoever and the music plays beautifully
Aux cable is running on same side of car as RCAs
Efforts made and results
Switched on Alpine HU
Selected FM radio
Noise - Same
Selected CD with no disc in drive
Noise - Disappeared
Removed HU's ground wire which was going into the harness & grounded it to the chassis
Noise - Same
Unplugged radio antenna from HU and removed from vehicle
Noise - Same
Removed HU from dash without disconnecting and moved it around
Noise - Same
Disconnected RCAs from DSP
Noise - Disappeared
Reconnected RCAs to DSP and disconnected them from HU
Noise - Disappeared
Replaced battery negative to chassis cable with a thicker one
Noise : Same
Plans
Replace engine ground cable with thicker
Replace alternator ground cable with thicker
Test with another HU if I can procure one
My gut feeling is that the Alpine HU has gone bad. But shouldn't one expect a defective HU to emit noise also in no disc mode?
My sincerest thanks in advance for your replies and apologies for the long post.
Problem
Selected FM radio
Noise - Same
Noise - Disappeared
Noise - Same
Noise - Same
Noise - Same
Noise - Disappeared
Noise - Disappeared
Noise : Same
Plans
