So I’ve recently switched amps and it was playing fine, installed it on my back seats. I noticed that it turned off, laid my back seat down and noticed the screws I Installed the with amp had came out, saw it was in protection mode. I’m running it at 1 ohm. It’s still loose right now. This morning it probably played for 10 mins then shut off but when I was leaving from work it played for about 30 mins on my way home. It’s not getting hot, I just wondered if it’s going into protection because the amp is moving around and the wires are being pulled. Because I got home and it was in protection, turned the car off then back on an it was working fine.
