I was doing some testing today, by leaving the amp's remote lead connected to constant. It was done intentionally for testing only. So I turn off the car, open the door, POP. Close the door, POP. Insert the key, POP POP POP. Turn on the light, POP. When the car is ON, I mean ON, not even with engine is running, no POP on anything I do. Is it normal that the car has that much noise when it's off and get to the audio system that easy? Or I need to make a new ground to the radio? Will the POP that I usually unheard of (normally it's mute because I use remote turn on from radio) cause any problem to the input section of the amp in long run?
Edit: I cannot ground RCA, because the signal from radio to amp is differential balance.
this is why you turn on amps last and turn them off first. HUs will have some turnon and turnoff thumps.
I know some amps need a noise gate installed to stop this from happening. You might want to try that approach.
