1 - 20 of 27 Posts
I was going to use a 3" port, but do to length, I will need to use a 2". I alrealy cut out the 3" hole in the baffle..... what can I do? also I can't get to the back of the baffle, because its so small.
need more info.
what size enclosure?
what size subs?
what is the tuning freq?
this biggest issue with going with a small diameter port is that you will raise port velocity. since you are going from 3" to 2", it will raise ALOT.
need more info.
what size subs?
.456^ft
single DD SW6.5
40Hz
port it would be 28" or so, but with the 2", it will be 9.91".....
ok, your port velocity goes from 113ft/s to 183ft/s, lol. that would not be good at all! not only would you start to expereince chuffing from the port, but with that kind of port velocity, it will start to act like a sealed box at higher volume due to port compression. I would stock with the 3"
this is based on 300 watts, if you have more than that, it will get even worse
only thing I can think of to solve your problem is to make a round cutout to cover your original hole and then cut a 2" hole in that.
just like a plug... thats what i thought... i dont wanna:rolleyes:
please go back and read my reply again. I edit it. a 2" port is bad idea IMHO
ok so, stay with a 3"... it will be getting 600.... what program are you using?
yeah 23.40"port length with 3" 9.91" with 2" port....
winISd, I have found it is pretty usefull for stuff like this.
with 600watts, the simulation says 170ft/s with 3" port and 380ft/s with 2" port. even as robust as that sub is, I doubt it will take 600watts, but even at half that, it is too high.
anything above 100ft/s will cause port noise and anything above about 120ft/s and you will start to see port compression. at 200+ft/s, might as well be a sealed box.
where are you getting this info, i too am using win isd
on the main window pull down. "rear port - air velocity"
change between the two diameters and you will see the differences.
I went to a speaker builder/manufacturer and ask him about porting and area required. Here is the link to the post
Acoustic Elegance • View topic - Ports
Been using his advice since. I believe it makes a huge difference in how a ported system sounds. I need to get a Dayton Omnimic to start taking measurements of my observations.
Discussion Starter #13
i don't have that...
do you have winISD alpha pro? that is the version I use. its still free, might as well update.
Discussion Starter #15
no.... ok i'll update, thanks
Discussion Starter #16
i cant get it to load
Either way port noise is gonna be bad. Think I would just run em sealed
Sent from my Motorola Electrify using Tapatalk
Discussion Starter #18
sealed... not gonna happen
Discussion Starter #19
ok, went on and finished it up... let me know what you think
looks nice..............hows it sound?
1 - 20 of 27 Posts
