Hi,
I have 3x Phase Evolution Aliante 12" SI Ltd subwoofers laying around. 1 of them is perfectly fine, but unfortunately the surface is deteriorated/damaged on 2 of them, and I would like to fix them so I can take them of shelf and get at least 2 of them to play some music again. One if them got minor holes/dents here and there, and the other one is bad case with multiple holes in a straight line across the entire membrane.
I attached a pdf with info about the Aliante subwoofers. On page 3 it says "Exklusive flat aluminium and fibre-glass membrane, ten times stiffer than normal cardboard membranes" as one of the features. The membrane to my knowledge is made up of a honeycomb aluminimum frame, which is then coated/covered with fibre-glass.
The membrane of the Aliante subwoofers is 100% flat compared to other common woofers which are more of a cone-shape. I believe because of the thick and 100% flat surface it might actually be a DIY job to fix the holes in the membrane - its not a fragile thin membrane, but more like a solid dish. It's probably not possible without altering the T/S parameters, but hopefully the repair will have minimal impact to that.
The holes can easily be felt with by running a nail softly across the membrane, and a whistling/high pitch noise can be heard when blowing air across the holes, while blowing in places where the membrane is intact it makes no noise and just deflects the air. .
Here is some pictures of the membranes - first one is not to bad, but aluminium honeycomb frame shows deformation (previous owner probably beat the hell out of that sub - hurray for buying second hand):
Here is pictures of the second which is not in good shape:
So what do you think? Would it be possible to add some kind of layer on top of the membrane to fix the holes without altering the charasterics of the sound to much? and what kind of substance/materiale would be suitable for it (nailpolish, glas fiber repair kits for boats, other more special stuff?)
Please chip in with any ideas if this can be fixed.
Another drastic idea... these subs where handmade and can probably be taken apart and put together again. Since the membrane is a flat dish and simple design it would probably be possible to make an exact copy of the membrane without to many special engineering/manufactoring tools needed. Getting replacements membranes in an strong+lightweight material might be possible, and take a leap of faith they will stay play nicely. I'm willing to throw some money at this just for the fun of it, since these are legendary subs.
Best Regards
Nicklas
Best Regards
Nicklas
