Okay folks, I was looking up some deadening stuff for the jeep. I have never used MLV before but am looking forward to the reduced noise that it is supposed to give me.
So I was allowing my brain to freely roam when a concept came up.
MLV- Most of it is rated at 1 pound per square foot right. It works by being a loose flexible material that is dense so therefore it blocks radiated noise. Many people find it hard to come by and some of the stuff stinks and is not flexible. It is around 1/8 inch thick so sometimes hard to squeeze behind panels.
I am not knocking it at all but just brainstorming.
So...
If its density and flexibility and the fact that it it decoupled from the surface is what makes it work so well, then what in theory would stop us from using something else that has the same qualities but is more readily available and more familiar to almost everyone in this hobby.
My theory is that I can simply order CLD (dynamat, second skin, SDS etc..) and adhere it with two layers (butyl adhered to butyl) and install it in the same manner as the mlv.
The reason why this concept has captivated my mind is because CLD is very flexible. It can have a similar density. Second skin Damplifier pro is .6lb/ft2 so two layers would be 1.2lb/ft2. The Kolossus kno knoise is 0.93lbs/ft2 so it would be almost 2lb/ft2 in two layers and could perhaps be used in 1 layer by adhering it directly to CCF.
I realize that this concept might not be as cheap as doing MLV but I am simply entertaining the idea that it could potentially be not only more effective that traditional mlv but also easier to use for instance under an area with tight confines since it can be squished down in the tighter areas. It could also be a more one stop shop type of product.
So to summarize-
1- Apply the CLD with about 25% coverage as you normally would.
2- measure out the size of the MLV layer that you normally would use but instead use two layers of CLD.
3- Use Closed Cell foam to decouple the double layer
In cases where the CLD is heavier like the kno knoise you could use one layer adhered directly to CCF.
Okay...go ahead and discuss...
Lets keep this topic on track and without any attitude.
So...
So to summarize-
