Power Acoustik Amp Issues
5K views 3 replies 4 participants last post by  supermaxx123
I got a power acoustic RZR-2500d and when it heats up it goes into protect mode... so if I turn it down to the level of amp staing cool enough, it won't shut down. I've recleaned the ground even moved it ground still did does it.. I just got a 12 inch kicker comp SVC 4ohm sub... need help diagnose the problem
#2 · (Edited)
Not your ground, not your amps issue. It's your issue, your asking too much of it. Probly driving it In to clipping and causing a bunch of heat build up. I say keep the amp gains where the amp is comfortable at. If you want more power I'd go with a more powerful and reliable amp. You'll end up damaging it and have to replace anyways.
Not to discourage you, but that amp is rated 450w @4ohm and most likely does not do rated power. Power Acoustik is also not known to be the most reliable.
