Hi!
Guidence and expertice needed
I noticed my lights dim when i play loud. After ive upgrade all and tuned with dsp.
My car: Passat 3c 1.9tdi
All led lights
140a alternator New 2 years ago
95ah AGM battery New 1.5 years ago
Big three with 50mm2 cable
Android head unit with optical output
Helix 8ch dsp mk1 with optical input
1 farad capacitator
Gz iridium 1000w in 1 ohm on 1farad cap
1 Rockford t1 12" 600rms sub
Helix a2 class a/b 150w*2 on 1farad cap.
Focal flax evo 6.5" running on helix a2.
JL Audio jx360 4ch class a/b 75w*4 not on cap
2 Focal Power 3" and tweeters running on jl audio jx360.
I run 2* 6.5 mids and 1 sub so i think my alt and battery should be enough power.
Planning to upgrade sub amp to better quality and to replace 6.5" with new focal power M series and put flax evos in back doors so then it would be 4*6.5" and 1 sub. I should be able to run that right?
Is the sub amp and helix amp to much for the 1 farad cap?
Should i keep 1 amp on cap and run rest on battery? Whitch one? Sub amp or helix amp?
Or sub amp on battery and rest of amps on cap?
I like the cap, i notice it kinda stabilizes all electronics in the car. Going on 400.000km and going Great!
Can i have tuned upp the signal and gains to much and dsp eq'ued down the bass so that i have low output that uses alot more power? Or does it always draw the power its needs to hit the bass notes, it just reqires more power after dsp tuned?
I also just noticed i forgot to upgrade my Ground cable from cap so its kinda thin and the weakest link in that case, can that be the cause?
Planning to go testing but its soo cold out these days xD
Sry if its abit much
Thx for help!
All led lights
1 farad capacitator
Thx for help!
