1 - 3 of 3 Posts
On the used Clarion dxz845mc that just arrived it has the term "power supply terminal" for illumination wire and for the auto antenna lead (different wire then the blue amp lead)
is power supply terminal a direct connection to 12v or a 12v accessory lead that only turns on with the ignition?
any help much appreciated!
* will be using pre outs only*
cut and paste from website
Brown wire (Phone mute lead)*
Connect to cellular phone mute lead.
Yellow wire (Memory back-up lead)
Connect directly to battery.
Yellow wire (Bus power lead)*
Red wire (Power lead)
Accessory 12 V
BluelWhite wire (Amplilier turn-on lead)
Connect to remote turn-on lead amplifier.
Black wire (Ground lead)
Connect to vehicle chassis ground.
OrangelWhite wire (Illumination lead)
Connect it to the car power supply terminal lor illumination.
Blue wire (Auto antenna lead)
Connect it to the car power supply terminal lor the antenna.
thanks again
randy
1 - 3 of 3 Posts
