Completely remove pac out if the loop and connect the stereo high level inputs to the high level inputs on the dsp, im not sure you tried this yet?
Yeah, run the speaker outs of the headunit straight to the 88r harness. On mine (while I had the stock HU in) I just clipped the RCA ends off the harness.I was considering taking the PAC out of the loop as a last resort, just because I don't want to pull my dash apart againMaybe this is a stupid thought, but what if I just "sacrificed" some RCA cables and hooked the speaker level inputs to them and plugged that in to the RCA cables that are already run? The DSP does use the same wires for high/low level input right?
Oh, I forgot to mention this is going to a PPI 5 channel amp(i640). The DSP, and AMP are meticulously mounted under my seat and out of site. That is one thing that is making me want to wait until all other options are exhausted, before trying high level inputs, since I will have to take it all out. I know, I should have checked it before doing that, but that would have made too much sense.... Thanks for the comments guys!
LOL, I gotcha! I already made a harness, soldered/heat shrinked and all. I just got through hooking it up, but I won't have time to really mess with until this weekend. Initial impressions are positive. I have even left/right distribution and nothing sounds weird. The signal is definitely better. I still had to split the front outputs though(RCA split). I have no idea why Ford thought it necessary to send different signals to front and rear speakers that are the same! I'll give you guys a better "review" after I've had some time to actually play with the EQ and make sure everything is working properly. Thanks for help/advice so far!You will want male as the harness has female (or im confused)... or just clip the ones on the harness and solder/heatshrink right to the wire.
Good deal :2thumbsup:LOL, I gotcha! I already made a harness, soldered/heat shrinked and all. I just got through hooking it up, but I won't have time to really mess with until this weekend. Initial impressions are positive. I have even left/right distribution and nothing sounds weird. The signal is definitely better. I still had to split the front outputs though(RCA split). I have no idea why Ford thought it necessary to send different signals to front and rear speakers that are the same! I'll give you guys a better "review" after I've had some time to actually play with the EQ and make sure everything is working properly. Thanks for help/advice so far!
That is exactly what I did last night. The PAC is out, and it is running on high inputs now. Unfortunately, just like everything I have tried before, this isn't working either. Everything I've tried sounds decent at first, but when I hop in to go to work the next day, the sound is back where I started?! I don't know what the heck is going on. This damned DSP is making me think I'm crazy!From what I gathered isn't that what he did?
HMMMMMM when you are tuning are you actually saving it to the DSP? You can save the file on your computer but have to save it to one of the save slots on the unit or it will go back to factory once you turn it off.That is exactly what I did last night. The PAC is out, and it is running on high inputs now. Unfortunately, just like everything I have tried before, this isn't working either. Everything I've tried sounds decent at first, but when I hop in to go to work the next day, the sound is back where I started?! I don't know what the heck is going on. This damned DSP is making me think I'm crazy!
It's almost like it's trying to sum the inputs every time it powers on after it's been off. No, my power/turn on are not crossed. It's flash memory anyway, so it SHOULD stay where it was I'd think. I'm really starting to think the DSP is faulty. No matter which channels go front or rear, two of the channels that are output(not counting G,H sub channels) are bass only or nothing at all. I can have good highs and some bass if I max out the gain on the amp for the sub while also reducing the gains for the channels A,B,C,D so the levels kinda match. They really don't though. There's some really wonky stuff going on here...
If I swap channels around going into the DSP I can get good sound from every speaker, just not all at once, so I'm pretty sure the amp is good. Tonight or tomorrow, I'm going to run straight to the amp just take the DSP out of the loop and confirm the amp is functioning as it should. If I rule the amp out, then all signs seem to be pointing to the DSP, which sucks![]()
Has anyone else had this kind of problem with the DSP-88R/Harmony? If I could get the sound where I wanted without the DSP, I wouldn't blown the $200+ on it in the first place. Does it sound like I'm on the right track on this troubleshooting adventure to you guys? Thanks for all the help so far!
Now that's just weird and was kind of a red flag in your other post. I don't personally have an answer for that one. If all this crap isn't working for you have you thought about contacting PPI support?and it sounded good...until I crunk the car up, and the input was all of a sudden way too hot even with the aux gain at minimum
