"They are great off axis but only left right, or up down depending on which way you point the grill." :worried: :surprised: :blush:
Oh good! I thought it was me.
How many times did you read it? :laugh: :laugh: :laugh:
"They are great off axis but only left right, or up down depending on which way you point the grill." :worried::surprised::blush::laugh: :laugh: :laugh:
It's hard to explain. The tweeters have a wide dispersion, but not a tall one. If you rotate the tweeter it will have a tall but not wide dispersion pattern. If you look at the grill you can see kinda what I'm talking about.
For mounting the outside of the housing is threaded and it comes with a lock nut to attach it. In my truck I mounted them in PVC fittings and drilled and tapped it for set screws to hold them
Just to let everyone know, these won't actually be out till around the first to mid Feb. they sent me the 2 pair they had a CES. I haven't gotten them installed but I will try to get a set playing in my wife's car this weekend. Here is some pics tho.
i fixed that post for you. please copy\paste above into your first post as not using [RETURNS] after IMG ruins the horizontal formatting of the forum. oh my god.
square ribbons do not suffer from the vertical narrowing, the latest LCY were built to improve on this issue, and therefore not all ribbon tweeters are subject to "ribbon tweeter sound" that is dependent on vertical dispersion being an issue.
Hello everyone ,
In this thread we will discuss rePhase and it’s uses on many different platforms to be used in a car. Let’s not talk about running jriver or cpu convolution unless it’s going to be used in a car for the most part this will be discussing FFT convolution and relatively lower tap...
"Smells like a man" she says as I open the box.......
Time for another Average Joe review! Remember folks, I am not a pro. I dont compete, I dont have thousands in test gear. I just listen to them in a car as you would in the real world and try to find the weak spots and what sounds really...
At last, the Biketronics BT4180 review!!! This has been months in the making; thankfully my day job has slowed down enough due to the holidays that I can finally write this without distraction. I’ve also attempted this review a few different times and scrapped each draft. It is difficult to...
Foreword:
While this review is intended to provide insight in to the use and subjective opinion of the end result of the MiniDSP with Dirac Live, it is not intended to be a full tutorial on how to tune with Dirac Live. I have linked various documents for that purpose. My discussion in that...
With the closure of SDS, along with some other companies on top of the creation of new companies like Resonix, its time to put these products through the gauntlet again.
I have plenty of time, but no funds to do this on my own, so I am fundraising to get this going. This test rig will be more...
