Hey Guys, been a while since I've roamed the forums. Hope everyone is doing well with all that is happening in the world today.
I need some help please from more experienced guys than myself with a ported enclosure design. The sub in question is an AudioFrog GB12 D2. I am going to be using a 4-inch precision port. I build plan I have come up with by doing some modelling in WinISD is 1.9 ft3 tuned to 30Hz. New the thing I can't seem to figure out is the port length; let me break it down:
Now the difference between 16.53 inches and 11.87 inches is a big deal. Can someone shed some light on this please and what would be the correct length to use in this case?
- As per WinISD under the 'vents' tab when left at default end correction (0.732), the port length I get is 16.98 inches
- As per WinISD again, if I change the end correction to two flanged ends, the port length is 16.53 inches
- As per Precision Port's website, the port length should be flare length port required (17.87844) minus 6 inches which is 11.87844 inches
