Hey everybody, I just bought a Rockford Fosgate 700s used. All though the amp looks brand new and there are no signs of it ever being hooked up or mounted I tested it to make sure it works. Know when I tested it I only ran it at very low volumes because it was late and in town so as to respect others.
The amp has dual 8 gauge hook ups for ground and power. I only hooked up 1 8g on both when I tested it. The amp worked great the fullf-hpf-lps all worked as did both channels, I did not adjust the gains do to not have proper tools. Then I unhooked the amp and brought it home.\
The next day I adjusted the gains to straight up/half way and then hooked it up with dual 8g for power and ground, hooked 2-12" single 4 ohm subs up to it in stereo.
This is where it gets odd -
1- Now the LPF lets more words pass and it didn't last night - Not right
2- I have to feel the subs to see if they are even hooked up, unless the gain is literally all the way up and deck volume is mid to high. If I turn down the gain at all sub just has really no power to it/like deck power would be - Not right.
I have been doing stereo's a long time and just dont want to admit the amp is bunk I guess.
All wirring is good in my car, its basiclly a test bench on wheels for some time know.
Any and all help would much appreciated.
Thanks
Brian
Thanks
Brian
