1 - 11 of 11 Posts
I am working on a new system for my 350Z and was considering running active. I've never ran active before and have been reading around and have a decent idea of what to do, but I am stuck at what to use for processing. I know it's best to use a active capable HU or a car audio orientated DSP like the MS8. I currently have a PIO double din, avic-f700bt, that I don't want to replace so that eliminates the active HU. I was thinking about a RF 3Sixty or MS8, but they're both a little pricey. I I am planning on running a pair of Mach 5 MLI 65's and am undecided on tweets. No sub, so I'd just be going 2 way. I still need to take measurements for the tweeter, I was planning on doing it soon when I have the chance. I was looking into the Behringer DCX2496. From reading around it seems that you have to use a computer whenever you make adjustments and I've hear this is less than ideal for a first timer. How exactly do these work? Is it true I'll need to hook to my computer for every adjustment? I was just seeing if you had any suggestions on a processor to run. I'd like to keep the price low, so a used one is probably the route I'll be taking.
Any help you can give me is greatly appreciated.
I also have a 350z, I was looking at the ms8 and bitone but like you said units are a little pricey. You can keep your head unit and just get a dsp from audio control. I'm in a similar boat as you so I'm looking forward to some advice from the experts.
Price to performance, you can't beat the miniDSP here... miniDSP Kits | miniDSP
One little 2x4 and a plug in and you've got a TON of control for ~ $120. Active crosses, T/A, a ton of EQ, etc. Down side is, yeah, you need a laptop when you need to make adjustments. But I've come to the realization that I don't need complete control on the fly so it's not really that big of a deal.
Even if you got a great processor like an AC EQL or whatever, it's not going to be dash mounted, so you wouldn't be able to really adjust it while you're driving anyway.
I was thinking that about the AC models minus the dash controller. Although a lot more convenient can't a person just run a an travel and make the minor adjustments from there. My dsp would be mounted right behind ma on an amp rack since its a two seater. I looked at the mini dsp but thought it might be over my head but I'm tired of buying eqment only to upgrade it a month or two later. Thanks for the advice. Sorry op didn't mean to thread jack but we're wondering the same thing
Sent from my DROIDX using Tapatalk
IDGAF thanks a bunch I'm def going with the mini dsp. Sending You a pm don't want to clutter op thread
PM area51 on these forums, he has a pretty much brand new mini dsp installed for a month, he ended up buying a bit one so I think he's gonna have it up for sale soon.
Thanks for the info
I think I'm going to get the MiniDSP. I've decided with the Mach 5 MLI 65's, I still need to measure for the tweeters, and for the amp I'm going to get the JL 300/4. Does this setup seem fine to run with the MiniDSP? Is it pretty complicated to set the MiniDSP through the computer?
if you check youtube the interface is very easy to work with.
1 - 11 of 11 Posts
