I'm trying to find a single processor I can use for the next phase of my car audio plans.
I want to go to a 3-way up front + subs, preferably with the option of trying rear fill, too. So, the processing needs seem fairly steep.
What do I think this processor needs to do, feature wise?
Minimum of 8 output channels - 1 stereo pair for tweeters, 1 stereo pair for mid-ranges, 1 stereo pair for mid-basses, 1 mono for subs, 1 mono for rear-fills
Each channel should have individually adjustable:
T/A (max of 1 ms steps prefer 0.5; minimum of 100 ms total delay)
Attenuation (max of 1 dB steps prefer 0.5; minimum of -10 dB total attenuation with a complete mute/off option)
Band-pass filters with selectable slope (must have at least 6/12/18/24 dB/oct - more choices in generally better)
Phase adjustment (180* flip at minimum - again, more choices is generally better)
Also, the processor needs to have separate L/R EQ with a minimum of 10 bands. 31 bands would be better. 31 band graphic in addition to a parametric EQ (5-10 bands) would probably be perfectly (PEQ for messing with tonality, GEQ for working out L/R FR differences - having both is simply a convenience).
For rear-fill, I believe it would be necessary for the processor to do a L-R signal as a selectable option.
Finally, none of these features are worth anything if I can't adjust them while sitting in the car. I would prefer a single processor with a DIN mountable controller or head unit integration; however, I would be open to solutions that require chaining multiple processors (Behringer, e.g.), and I would be open to solutions that required a laptop to adjust the bulk of the settings but I much prefer something I can adjust at any time with a permanently installed controller interface. Also, perhaps obviously, I must be able to change these settings while a signal is being produced (absolutely no: listen, turn off, adjust, turn on, listen again cycles - I need to hear changes in real time while music/tones are being played).
So, is there anything that can do all this? (rear fill is more of an option, so I'd consider processors that failed only on that part. The rest is pretty much essential)
I think two DEQ2496's would do everything I need, except be controllable in the car (deal breaker there) and it starts getting spendy (though for what I'm asking I almost have to say this is a cost-no-object item).
BitOne may come close, but this ain't horseshoes or hand grenades, and with all the previous issues I'm honestly very unlikely to try it (don't need fanboi's telling me how they've fixed everything now, kthxbai).
Custom in-car PC setup would probably do it, too, but I'd really rather have an "appliance" specific to the purpose, if one exists, because I'd rather invest the time learning to tune rather than learning how to build a car pc.
The Ural Concert HU, which I saw for the first time recently, comes surprisingly close and I really like the interface (mainly the ability to group settings and adjust them simultaneously - but it is missing a couple key things (sub channel that isn't tied to another channel's T/A) and next to impossible to get it seems.
Any other options to get what I need? Did I miss any essential features I should be requiring?
