Yeah... if it's going in a door though I don't know how much more people would be willing to spend to make it look a bit nicer. The cast frame is very heavy and rigid, and the driver as a whole is very functional. Custom tooling for a nicer frame, a more exotic cone material, a nicer one piece top plate (like what you see with Brahma, Avalanche, XXX, etc.) costs alot more money.daitrong said:i know this is a prototype and cosmetics will change ( i hope they do ) but it looks really ghettoo. Sorry, had to point out the obvious.![]()
It's an xbl^2 motor... no plans on a mid/bass only version with metal cone.blackreplica said:A few questions for you sir!
Firstly, is that really using an underhung motor?
Secondly, will you ever be making a midbass-only version, maybe something with a rubber surround/metal cone?
Third, does that dip you intended in the 150-300Hz region sap away midbass impact?
And last of all, what's the qts of that mofo?
/me waits anxiously for benchmarks against the excel
it's 88db efficiency =/ wasn't the lcy 130 ribbon 93dbwm ? if so i would think a more efficient driver would be a better choice to mate with the lcy in a 2 way set up.cam2Xrunner said:So what tweeter do you think would work best with this?
Which ribbon-
vibrator said:very impressive! looks just fine to me. I say keep the price low, dont worry about cosmetics. Most people hide them behind grills anyway.
Do you think this driver will give the Peerless XLS 8 a run for its money in terms of bass output?
Heheh you gotta remember the Peerless XLS is an 8" driver, with a 26mm long coil! And it's nearly 4" deepvibrator said:vibrator said:very impressive! looks just fine to me. I say keep the price low, dont worry about cosmetics. Most people hide them behind grills anyway.
click here for specs or google the part # 830491blackreplica said:Thank you sir!
i'm still on a slow hunt for that elusive 'perfect' midbass driver. I tried checking thru your microsoft excel catalog to find out more on this XLS 8 inch everyone is talking about. It's listed on your first worksheet but when i click the name i get linked to a SEAS driver specs instead...the closest thing i could find matching the description is this Peerless HDS 8 inch, is that the XLS you're talking about? The xmax sounds yummy, where can i get more details on this unit? Didnt see anything on the d-s-t website either. I take it the peerless really excels (sic) even when IB?
