1 - 2 of 2 Posts
D100.4 Specs:
Class AB 4-Channel Amplifier
Specifications
• 4 Ohm RMS Power: 100W x 4
• 2 Ohm RMS Power: 150W x 4
• 4 Ohm Bridged RMS Power: 300W x 2
• PEAK Power: 1200W
• Minimum THD: <0.01%
• Frequency Response: 10Hz - 65 kHz
• S/N Ratio: >100dB
• Damping Factor: >600 @ 100Hz
• Channel Separation: >65dB
• Dimensions (L x W x H): 12.4" x 8.6" x 2.4"
Features
• High Speed MOSFET Power Supply
• BiPolar Japanese Sanken Output Transistors
• 16V Capable Power Supply
• Copper Rail PCB Architecture
• 24dB Crossover Circuitry
• Adjsutable Subsonic Filter via HP Crossover
• Band Pass Capable
• Adjustable 12dB Bass Boost @ 45Hz
Control Panel Features
• Remote Bass Control via RJ11 Jack (Remote Not Included)
• Input Mode: 2 or 4 Channel
Channels 1-2
• Gan 9V to 0.2V
• Clone Channel 3 & 4- FR / HP Allows you to set CH1 and CH2 to High Pass or Clone. The Clone feature aligns CH's 1 and 2 to CH's 3 and 4 thus giving you uniform sound
• High Pass Frequencies: 10Hz - 300Hz or 150Hz - 4.5 kHz (with a 15x frequency multiplier switch activated)
Channels 3-4
• Gain: 9V - 0.2V
• LP/BP - FR/HP Control
• High Pass Frequency Control: 15Hz - 500Hz
• Bass Boost: 0dB - 12dB
• Low Pass Frequencies: 45Hz - 450Hz or 450Hz to 4.5kHz (w/ 10x frequency multiplier switch activated
• Accepts 4 Gauge Power & Ground Wire // 10 Gauge Speaker Wire
Vegas Specs:
Specifications:
• 4 Ohm RMS Power: 135 Watts x 4
• 2 Ohm RMS Power: 225 Watts x 4
• 4 Ohm Bridged RMS Power: 450 Watts x 2
• Frequency Response: 10Hz – 40 kHz
• S/N Ratio: >100dB
• Damping Factor: >220 @ 100Hz
• Dimensions (L x W x H): 24” x 7.25” x 2.25”
Features:
• Studio-Grade Bipolar Output Stage Transistors
• Fully Adjustable 12dB / Octave Crossovers
• Low Pass: 40Hz – 150Hz
• High Pass: 50Hz – 500Hz
• 18dB Bass EQ Boost Control
• 3-Channel Mixed Mono Capable
• Mute and Delay Soft Start System
• Full IC-Controlled Protection Circuitry
• Fully Adjustable Subsonic Filter
• Dashboard Bass Remote Control Included
• 8 Volt Pre-Amp Circuitry
• RCA Pre-Amp Line Output
• Input Mode Selector Switch
Q4000 Specs:
Specifications:
• 4 Ohm RMS Power: 125 Watts x 4
• 2 Ohm RMS Power: 190 Watts x 4
• 4 Ohm Bridged RMS Power: 380 Watts x 2
• Minimum THD: <0.1%
• S/N Ratio: >97dB
• Damping Factor: >150 @ 100Hz
• Channel Separation: >50dB
• Input Voltage: 200mV – 8V
• Dimensions: 16.9” x 7.9” x 2.4”
Features:
• High Speed MosFET Power Supply
• BiPolar Professional Audio Grade Output Transistors
• 16V Capable Power Supplies
• 12dB Crossover Circuitry
• Bass EQ
• Crossover Modes: Low Pass / Band Pass, Full Range, High Pass
• Input Modes: 2Ch, 4Ch
• Low Pass Frequency: 50Hz - 500Hz (Ch3 & 4)
• High Pass Frequency: 50Hz - 500Hz (Ch1 & 2), 50Hz - 150Hz (Ch3 & 4)
• Bass EQ: 0dB - +12dB (Ch3&4)
• High Level Inputs
• Line Level Inputs
• Smart Turn On: Music Sense / DC Sense (High Level Inputs)
• Power / Diagnostics LEDs
• Accepts 4 Gauge Power & Ground Wire // 14 Gauge Speaker Wire
MRX F65 Specs:
Features and Specification
CEA-2006 Power Rating: 110W RMS x 4 (4-ohm, 14.4V at <1% THD+N)
Max Power Output Ratings
Max Power: 1200W
RMS Power Ratings
Per channel into 4 Ohms: 110W RMS x 4 (14.4V at Ƈ% THD+N)
Per channel into 2 Ohms: 160W RMS x 4 (14.4V at Ƈ% THD+N)
Bridged 4 Ohms: 320W RMS x 2 (14.4V at Ƈ% THD+N)
Sound Tuning
Crossover Frequency (HPF): 50 - 400 Hz, -12dB/oct.
Crossover Frequency (LPF): 50 - 400 Hz, -12dB/oct.
EQ (Equalizer): 0 to +12dB (CH3/4, fc=50Hz)
Dimensions
Foot Print (WxHxD) mm: 270 x 58 x 230 mm
Foot Print (WxHxD) in: 10-5/8'' x 2-1/4'' x 9''
Heat Sink (WxHxD) mm: 210 x 58 x 230 mm
Heat Sink (WxHxD) in: 8-1/4'' x 2-1/4'' x 9''
General
Power Requirements: 14.4 V.DC (11-16V allowable)
Input Sensitivity (RCA Input): 0.2 - 4.0 V
Input Sensitivity (Speaker Level Input): 0.5 - 10 V
Input Impedance: >10k ohms
Frequency Response (+0, -3dB: 1W into 4 Ohms) for CH-1/2/3/4: 5 - 45k Hz
THD+N (10W into 4 Ohms) for CH-1/2/3/4: Ɔ.02 %
THD+N (100W into 4 Ohms) for CH-1/2/3/4: Ɔ.07 %
Damping Factor for CH-1/2/3/4: >500
Signal to Noise (Rated Power into 4 Ohms) for CH-1/2/3/4: 106 dB
Weight: 2.7 kg
FEATURES
Install
Terminal Layout: Two-Sided
Screw Mount / Wire Cover: Integrated Wire and Mounting Screw Terminals
General
Amplifier Type: Class-D (Digital)
Channel Design: 4/3/2 Channel
Power Supply Design: DC-DC PWM Power Supply
Power Supply: MOSFET
Final Outputs: Direct FET
Crossover: Variable Low Pass & Hiigh Pass Filter
Gain Control: Continuously Adjustable Gain Control
Bass EQ: Bass EQ Function
Thermal Control: Multi-stage Power Limiting
Low-impedance Possibility: Low-impedance Possibility
Current Protection: Over-Current, Over-Voltage and Thermal Protection
Board Circuitry: S.T.A.R. Circuit
Board Design: 6-layer Glass Epoxy PC Board
Speaker-Level Inputs: 4-channel Speaker Level Inputs
Power Indicator: Top Mounted Blue LED Power Indicator
1 - 2 of 2 Posts
