1 - 19 of 19 Posts
· Registered
Looking for a quality RCA cable that will not break the bank. I have had the stinger 800 series cable, and they where real descent, but the jacket eventually came unraveled and stop sending a signal to the amps. Then i went with the new Knukonceptz Krystal cable and i noticed something lacking in the sound, highs where not as crisp as they where with the stinger cable. Any suggestions would be appreciated thank you.
· Registered
· Registered
are these equivalent to the 8000 series audiophile grade cables.
The HPM3 Stingers with Blue aluminum barrels, are the top of the line RCA's, there was a previous generation with silver and shorter connectors. Then these, after the nice blue ones they came up with the 8000 series.
With any RCA cable you buy, I SUGGEST, YOU PLUG IT TO AN OLD TV OR RCA COUPLER BEFORE YOU PLUG IT TO THE AMP, JUST TO TEST THE TIGHTNESS, IF IS TOO TIGHT, UNSCREW THE BARREL AND PLUG AGAIN AND TWIST IN A CIRCULAR MOTION TO ADJUST THEM AND THEN, SCREW THE BARREL BACK ON AND TEST IT AGAIN
I used these myself and I have had no issues, other than the minor adjustment I had described.
Westco's cables are great cables if you want to try something different that is top quality.
· Registered
· Registered
They are the exact same cable with different aesthetics. I've run both and they are excellent quality. They also offer locking barrels which is a nice bonus. Reasonable pricing too.
· Registered
· Registered
I'll throw my hat in for WestCo's cables defiently the most quality cable I've ever handled/used.
1 - 19 of 19 Posts
