Few quick questions,
Currently running some old passive components (no rear fill) and an MB Quart RWE-354 sub off a U.S. Acoustics USB-4085. Decided it was time for an upgrade so I pulled the trigger on a set of HAT Imagine 6.5" components and an Audiopipe APSM-1300 as a dedicated sub amp, sadly I don't have the funds to buy an active x-over or a new deck.
I know the HAT Imagines are intended to be used as coaxials so the tweeters are a few DB's too loud when you use them in component mode. My goal is to use these in component mode (tweeters in sail panels) but if I could use my 4-channel amp to its full potential while also giving me a little taste of active I'd be stoked
. I've read that it is possible to run HAT 3-way speakers directly off a 4 ch amp with capacitors inline with the tweeters. I'm wondering if I can do this with the Imagine components - one amp channel per speaker since I'll have freed up the channels I was using for the sub, do I still need to run the capacitors inline with the tweeters?
One more question
I'm running the U.S. Acoustics 4085 off a knukonceptz 8gauge wiring kit, what would be the preferred method to add the APSM-1300? Would this 4 gauge wiring kit w/ dist. block work for both amps? Saw on here this is pretty much the best budget 4 gauge kit you can get.
Thanks
One more question
Thanks
