I'm not familiar with the R QIDI as a specific model; but in general --
* Be sure that the nozzle and related parts are fairly standard. For nozzles, that means e3D compatible.
* Be sure that the firmware has adjustments for the steppers on the extruder and the heating elements PID functions. Hopefully it'll come pre-tuned well enough that you don't have to mess with it, but if you later want to try something new, having adjustability is better than not having it.
• Be sure that you can fit larger nozzle sizes to it. Small diameter nozzles make for good detail, but for a lot of stuff detail isn't needed, speed of printing and strength of the resultant part is. Larger extrusion sizes are both faster to lay down and stronger. A machine that can handle an e3D Volcano or SuperVolcano would be great for making stuff like speaker pods, for example. On the other hand; if you are wanting to do super detailed stuff like tabletop gaming figurines (custom WH40K pieces, for example) you might wish to look into a liquid-resin based SLA printer.
* ABS and many (but not all) liquid resin formulas stink; but they also don't like being without environmental control (i.e, HVAC). Factor this into where you intend to set up the machine.
• As mentioned earlier in the thread, PLA doesn't stink and is pretty much nontoxic (at least, the plastic itself is - any particular filaments additives & pigments may not be)... but... it has a rather low melting point; so it shouldn't be used for parts that could be left in a car. PETG is low-odor, relatively innocuous chemically, has decent temperature tolerance, and isn't too hard to get to print well. It's what I use in my printer. However, PETG is a little bit softer at room temperature than PLA is, which feels quite rigid when you tap your fingernails on it.
* Most 3D printers take job files on micro-SD cards. Make sure you have a couple on hand, along with micro-to-standard SD adapters (which often comes with the card for free). Cheap, small ones work OK - the actual job files aren't very large, and the flash storage is far, far faster than the speed of the print head. Also, make sure you've got a card reader that's convenient to use. The built-in one on my MacBook Pro works just fine for me, but the one on my iMac is a pain because it's on the back of the machine (seriously, Apple, what were you thinking?) -- so I got a cheap USB one that sits on my desk.
• I too use Fusion 3D for technical parts design. Works OK, noncommercial license is (as note earlier by other posters) free.
• If you are looking more to do artistic work, then Blender is a good free option. Be sure to get a Wacom tablet, as you will want to use it's digital sculpting engine.
• Subscribe to some YouTube channels: Maker's Muse, Thomas Sanladerer, and CNC Kitchen are all great ones, but there are many others. Expect to spend a lot of time watching videos... they're addictive, inspiring, and informative!
I also agree with these lists for Blender and Fusion360:
And we're back again with another compilation of YouTube channels where you can learn how to use Blender, a powerful free and open-source tool for 3D artists.
80.lv
Getting started with Fusion 360? Check out the tutorial videos on these free YouTube channels.
www.makeuseof.com
• In addition to the 3D scanner of the new iPhones, you might want to look into photogrammetry software. I haven't personally used it, so I don't know how well it performs, but... Regard3D is both free/open-source and runs on a Mac.
Home
There's a ton more to this field, but this post is longer than I intended anyway, so....
